Misc Parts Dump
$1
toddc
Sagle, ID
2 ea. 12.1 Non-ABS Rear Halfshafts- $850
2ea. 12.1 Upper Gear w/bearings- $275
Rubber Door Glove Box- $100
Alpha Accelerator Pedal Bracket 6017872- $40- SOLD
Front Door Wiring Harness(power door locks and windows) 6003591- $200- SOLD
Hood Latch Strap + Bumper- $30
Door Lock Actuator- $30
Lower Windshield Trim Gray 6010265- $100. (HPG current price is $226)
IP Lower Edge Close-Out Piece 6006289- $20 SOLD
Front 10.3 Driveshaft with fresh U-Joints and Carrier Bearing(Used)- $200- SOLD
All parts new except as noted. Price does not include shipping from zip 83860.
For the rubber door glovebox, what goes in the hole on the front? The lock I’m assuming?
I have no door on my current glovebox so I don’t have a current lock. Is there a part number of the lock I could buy for it to go along with the glovebox you’re selling?
So driver's door has to be locked or unlocked manually because when I press any of the lock buttons, it makes a noise like it is attempting to lock or unlock but will not fully move the post. That is the lock actuator that is causing my problem, right? If so, your door lock actuator should fix that problem?
They can also be disassembled, cleaned, relubricated and reinstalled. If you do a quick search you'll find a bunch of people who have resurrected them.
