white out
- Joined
- Oct 16, 2003
- Messages
- 2,213
- Reaction score
- 136
Ordered 2 of these since there was a long lead time and my truck was down. Now have a spare.
$550 shipped within US
Retail: $575
Images are of the balancer I opened and put on my truck. Listing is for a new damper sealed in factory box.
Manufacture info:
Fluidampr Balancer for Hummer H1 with 6.5 (electronic fuel pump)
No tuning or maintenance required - Designed to last the life of the 6.5!
The OEM 6.5 dampener is made of rubber and steel and will deteriorate over time and eventually fail, which will destroy the crank and engine. If the OEM damper has never been changed it likely needs to be due to age alone and should be changed by 100,000.
Protect your 6.5 with the technology high power diesel OEMs use. A Fluidampr performance diesel damper provides premium, broad range control of destructive crankshaft torsional vibration for optimum performance and durability. Fluidampr reduces wear on critical internal engine components when engine modifications are done to gain horsepower or when rotating assembly parts are upgraded. Features high quality, long lasting viscous silicone with precision CNC machined and computer balanced high-grade steel components.
Bore Diameter 1.5993" Degree Marking Range 50 degree BTDC to 10 degree ATDC.
Additional timing/degree marks at 90, 180 and 270
Degree Markings Engraved
Engine Balance External
Finish Black Zinc
Keyway Single; (3/16")
Length 2.443"
Material Steel
Outside Diameter 8"
Safety Rating SFI 18.1
Weight / Rotating Weight 17.7 lbs / 11.8 lbs
Retail: $575
Manufacture info:
Finish Black Zinc
Length 2.443"
Material Steel
Outside Diameter 8"
