NickInMN
- Messages
- 782
- Location
- Farmington, Minnesota
Front differential protection 12460415 and rear differential protection 5593492 - They were modified to fix 12 inch brake rotors so they can be used with 10 or 12 inch rotors. SOLD
Air Cleaner Housing 12339911 - The canister is in good shape. The clamp for the cover is not included. It has two 5/16 x 1/8 NPT barbs on it that were connected to the transfer case and transmission vents. I can also include the filter, it has about 6000 miles on it.
SOLD
RubberDuck Frame Reinforcement - $40
Hood lift blocks - $35
Idler Arm Spacer - $30
Under hood Lamp 5939456 - $50
Parking Brake Bezel 6000436 and Trans & Transfer Case Shifter Bezel 6007186 -Both are in good shape. There is one crack in the transmission bezel, see the picture. I can include the gasket and push pins with the parking brake bezel if desired.
$60 each or both for $100
Battery to Battery Negative Cable 6003128 & Battery to Battery Positive Cable 6003129
SOLD
Ignition Interlock Cable 6007700 - In good working order, both ends are undamaged. The grommet has some weather cracking.
SOLD
Differential Cover 5582303 - SOLD
Intake Cap, adapter and elbow - SOLD
Pinion Yoke 5717032 - $20 each, two available
Pinion Yoke (12k 1350) - $35
Prices do not include shipping.
If you want more pictures of anything just let me know.
SOLD
SOLD
SOLD
