Original Warn Winch 6019637
$2500
MT H1
Montana
Original Warn 12,000 LBS winch, includes mounting bracket, both battery cables, fairlead, remote. Bought as a spare. $2,500.00 FOB 99148.
  • Rated Line Pull: 12,000 lbs (5,440 kg) single line
  • Motor: Series-wound, high-speed 12V DC motor
  • Gear Train: 3-stage planetary geartrain for smooth, reliable pulling
  • Brake: Automatic mechanical brake for superior load control
  • Rope: 125 ft of 3/8-inch (38m of 9.5mm) diameter wire rope
  • Control: Remote-mount control box with a handheld remote
  • Mounting: Requires a compatible winch bumper or mount (often standard or optional on H1 specific packages) [1, 2, 3]
Performance & Line Speed (Full Load)
  • 0 lbs: 38.0 ft/min (11.58 m/min) no-load line speed
  • 12,000 lbs: 3.86 ft/min (1.17 m/min) max load line speed
Overall Dimensions: 24.37″ L \(\times \) 8.45″ D \(\times \) 11.0″, Weight Approximately 150 LBS
