Selling a complete 1999 hummer H1 chassis performed a Duramax swap on another chassis, basically just took the body off this one. Chassis is complete from brake system to cooling system to fuel system. Brakes are complete from calipers to ABS module with computer as well. Cooling system is complete with Griffin aluminum radiator new oil cooler that only has 200 miles on it, Power steering cooler, AC condenser and custom intercooler. Engine was replaced under warranty with a newer 2000 model only has 60,000 miles on new engine. Turbo has a billet wicked wheel installed . Transmission and transfer case were well-maintained and work properly. Fuel system is complete. The main fuel tank is not pictured but I have it, Steering system is complete from the steering box to the pump to the cooler and all the required lines that go to the Hydro boost. I also have the engine wiring harness and ECU. I have several videos of the engine running and the hummer driving and shifting prior to removing the body. 6500 OBO for the complete chassis. Wheels and tires are not included. I do not want to part it out but if I do prices are below.
Part out price
Portals 1800 for all 4
Differentials 1500 for the pair
Complete Engine with stock intake and front drive 2300
Starter 500
ECU 300
Abs module 700
Griffin aluminum radiator 600
Basically new oil cooler 400
Intercooler setup complete with intake 1000
Cv shafts 400 for the set
4L80 transmission and transfer case 800
Condenser 100
Any other parts message me. Package deals available.
Located in Ohio 43040
Part out price
Starter 500
ECU 300
Abs module 700
Condenser 100
